Inventor Forum
Need help, please
9 REPLIES 9
Message 1 of 10
pineapplexpressdf
915 Views, 9 Replies
Need help, please
Hi, I'm currently out of the country and forgot to convert my part into a parasolid (xb) for CNCing. I can't get inventor here, could someone pelase download this, convert it, and post the parasolid? Thanks in advance
9 REPLIES 9
Message 2 of 10
I'm still stuck on Inventor 2012 so I cannot help you on this one.
BTW... For post like these, it is really important to state what version of inventor you are using.
Mike Patchus - Lancaster SC
Inventor 2025 Beta
Alienware m17, Intel(R) Core(TM) i9-10980HK CPU @ 2.40GHz 3.10 GHz, Win 11, 64gb RAM, NVIDIA GeForce RTX 2080 Super
Did you find this reply helpful ? If so please use the Accept as Solution or Kudos button below. 🙂
Message 3 of 10
jaybear
in reply to: pineapplexpressdf
I attempted it.  Hope it works. I had to zip it because the forum wouldn't let me post an x_b file.
Message 4 of 10
@pineapplexpressdf wrote:
... forgot to convert my part into a parasolid (xb) for CNCing....
The hole for the 1/4-20 thread is the wrong diameter.
The correct tap drill size is a #7 drill (.201) or something close.
You made the hole .25, there will not be any material for drilling.
Use the Hole tool to create threaded hole features and you can avoid this beginner mistake.
Also, flat bottom holes are more expensive to make than drilled with standard 118° point and bottom tapped holes cause lots of trouble (read expense).
Message 5 of 10
JD,
You just saved someone a lot of grief there.  Kudos
T.S.
Message 6 of 10
mpatchus
in reply to: JDMather
It still amazes me how many folks still create holes by drawing circles instead of using the hole tool provided in the software.
Inventor 2025 Beta
Message 7 of 10
Paul-Mason
in reply to: mpatchus
1/4 - 20 is that looks like a whitworth thread ? In which case BSW threads ARE NOT included in the standard tread.xls file. you'll need to find or ask some one for the file who has these threads.
Inventor 2023 Pro
HP Z420 workstation
Xeon 3.7Ghz CPU 8 Cores, 64 GB Ram
64bit (The Garbage known as) Windows 10 Pro
AMD FirePro V3900 (ATI FireGL) (1GB RAM)
Ashington Northumberland (UK) ~ Home to the WORLD FAMOUS Pitman Painters Group
Message 8 of 10
JDMather
in reply to: Paul-Mason
Editing the feature shows that the specification is an ANSI 1/4-20 UNC.
ANSI = American National Standards Institute
UNC = Unified National Course
1/14-20 UNC is a common inch fastener size used in the States.
The file indicates that it was created in student license of Inventor.
Message 9 of 10
jdkriek
Nice catch JD
Jonathan D. Kriek
MFG Solutions Engineer
KETIV Technologies, Inc.
Message 10 of 10
JDMather
I meant to write, 1/4-20 UNC, not 1/14-20 UNC.....
