Inventor Forum
Need help making a sheet metal punch tool
4 REPLIES 4
riveter1000
2621 Views, 4 Replies
I am trying to make a punch tool using Extract iFeature. I have followed instructions I found online. The iFeature does not like my part. The problem seems to be centermarks. I went into my sketches and tried to make sure I only have one centermark, the one in the first sketch. But there seems to be centermarks I can't identify.
Where am I going wrong here?
Using Inventor 2013.
File attached.
Mark
Inventor Professional 2015 SP1
System Specs:
Dell Precision M6800
CPU Intel I7-4600M
RAM 16 GB
Graphics Nvidia Quadro K5100M
Tags (2)
4 REPLIES 4
JDMather
in reply to: riveter1000
Almost everything you have done is not correct - starting with an Adaptive part.
 see this recent thread
http://forums.autodesk.com/t5/Inventor-General/punch-feature/td-p/4829671
Besides everything else that is wrong -
the first sketch in your Punch iFeature is Sketch3.
Sketch3 does not have a sketch centerpoint.
You could add Sketch2, but I recommend you start over from scratch.
You might also provide the url to the instructions you are attempting to follow.
riveter1000
in reply to: JDMather
Jd - I went through your tutorial. I have everything referenced to one line and only one center point. When I do the Extract iFeature it tells me there is more than one centerpoint.
Will you take a look at my model?
Mark
System Specs:
CPU Intel I7-4600M
RAM 16 GB
JDMather
It sounds like you have Sketch1 selected - you should have only Sketch2 and everything below selected.
Show the same screen capture like you did before.
Also, why are your sketches and features showing as adaptive (red/blue arrows)?  Are you doing this part in the context of an assembly?  It seems to create a punch even though adaptive, but I recommend beginners avoid adaptive.
riveter1000
I turned off adaptive where I could.
Anyway, through a process of making every error and combination thereof, I got it to work.
Your tutorial was a big help JD.
The resulting standoff:
Mark
System Specs:
CPU Intel I7-4600M
RAM 16 GB
