Hello. I need to model process of tensile test for my diploma project. I had created a specimen of metal and tested it. But the main goal is to test metal sample coated with polymer coating. I have no idea how do this. Looking for any help!!
Solved by CCarreiras. Go to Solution.
Hi!
Model the two parts, the metal and a thin part (the polymer)
Join both in one assembly.
Test with the FEA module and ensure both parts have the face bonded.
Ok, i've build a kind of coating and joined it with specimen. But I'm not sure i had made it correctly, because test result is not quite right in my opinion. Could you check my assembly for me please?
@nahalem wrote:
... because test result is not quite right in my opinion. ..
Why do you think the result is not correct?
