I've searched through many topics on this subject and haven't found anything that will help me import this Solidworks 2011.STEP. Can anyone turn this .STEP into a usable inventor part?
I'm using Inventor PRO 2012 64-bit.
What you see is what is in the file.
I recommend you request a file saved as a solid.
Of course someone could reverse engineer and create most of the solid, but it would probably cost a bit to get the results.
Doesn't look like it would be too bad to recreate (mostly a Revolve) if one knew what the end parts would look like.
