Inventor Forum
Need dims in iso views
4 REPLIES 4
333 Views, 4 Replies
I'm being asked to dimension a part that predates me, and I'm having trouble with it. This part is confusing to the break operators, and I can see why. I'm trying to dimension the ends of this part in the iso view, but I'm not able to get them as easily as I was hoping. We need outside dimensions for these flanges. How best to go about what I'm doing?
4 REPLIES 4
Cadmanto
Dimensioning in iso views is not easy as you are finding out.  Especially when it comes to tangency.  My suggestion would be to add sketch lines to this view and dimension to those.
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! Smiley Very Happy
Best Regards,
Scott McFadden
(Colossians 3:23-25)
JDMather
It may also help to have the hidden lines turned on while dimensioning or creating sketch geometry to dimension to.
in reply to: Cadmanto
Thank you, fellas. I'm sure you'll be glad to know that I put the gun away and decided I wanted to live, probably a direct result of your help. Turning on hidden lines did help immensely in getting the sketch geometry I needed drawn so I could dimension this still very ugly part. Thanks.
Cadmanto
You're welcome.
That is a good thing you decided to stick around!!!!
Best Regards,
Scott McFadden
