I also would like to link the perimeter of an object to an .idw.
Has any progress been made on this issue yet?
If the part that needs the loop measured is a sheet metal part then I have a macro (supplied by a friend) that generates 3 Custom iProperties, InnerPerimeters (all internal shape holes/cutouts lengths added together), Outerperimeter (the outer shape length and TotalPerimeters that adds the previous 2 together. Let me know if this is of any use and I can post it.
Give this a try for Laser Cuts. Has some pretty nice options to it.
http://www.morecam.ch/ilasercut.html
Mark Flayler - Engagement Engineer
IMAGINiT Manufacturing Solutions Blog: https://resources.imaginit.com/manufacturing-solutions-blog
Brendan, Mark,
Thanks for replying. The perimeter I require however is the end profile of an alunimium extrusion.
The iLaserCut app is a nice little addin but only worked in the flat pattern environment and I presume the app you had in mind does the same Brendan.
If their is an app that would write the autolimits value out to the Properties dialogue, that would be useful.
