I accidentally clicked on the "X" to close the Navbar under the orthographic display. It comes back when I restart inventor, but I'd rather not have to do that. Inventor help doesn't tell me where to turn that visibility on or off. Or maybe I just missed that instruction.
Solved by jtylerbc. Go to Solution.
Click the View tab, then "User Interface." You should then be able to turn the check box back on for the navigation bar.
Thanks. I actually had to customize the view ribbon to add the navigation bar as a custom user command. that allowed me to toggle it on and off.
