Inventor Forum
Mysterious ( i ) next to a feature help?
8 REPLIES 8
Message 1 of 9
pkquat
4475 Views, 8 Replies
I can't seem to get any information about it. I don't see any points off in space. What am I missing?
I deleted and recreated the feature (a set of holes) and I got the same ( i ).
This started from a part where a cutout was removed from the first extrusion and I was left with a pink dot. I deleted the reference line with the pink dot, lost a bunch of dimensions, projected the new line, and re-dimensioned. Its worked before.
Pete
8 REPLIES 8
Message 2 of 9
in reply to: pkquat
>Pete
Well can't really tell you why it is, but it appears that the
construction lines in the sketch caused the i to appear.
I removed the construction lines and used sketch constraints instead
to position the holes along with the required dimensions. Away went
the i...
Stephan
2003 Yamaha R6
kimi no koto omoidasu hi
nante nai no wa
kimi no koto wasureta toki ga nai kara
Message 3 of 9
in reply to: pkquat
Message 4 of 9
in reply to: pkquat
Wow! 2 in 1 day! See icon meaning thread from a couple hours ago.
wrote in message news:5220722@discussion.autodesk.com...
i ).
Its worked before.
Pete
Message 5 of 9
smjanows
in reply to: pkquat
Yes this is strange. I decoupled the sketches from each other and moved your problematic stetch to the end. So all your dimensions in this version are gone as well as the construction geometry to try to isolate the problematic features.
It seems like 3 holes in the sketch are causing all the problems. Those points are not included in the holes and the ! disappeared.
Message 6 of 9
in reply to: pkquat
Pete,
This is indeed a weird one. I delete the vertical dimension of 2.25in and
recreate the dimension and update the part. The feature becomes healthy.
Regarding why the (i) appears, I have to forward it to development for
review.
Thanks!
Johnson Shiue
Test Engineer
(email: johnsonDOTshiueATautodeskDOTcom)
i ).
Its worked before.
Pete
Message 7 of 9
in reply to: pkquat
Sometimes you'll get one of these informational warnings if your sketch has
lost its parent face or coordinate system.
Message 8 of 9
pkquat
in reply to: pkquat
Don't those normally show up on the sketch? I did try a redefine the sketch face, but that did not have an effect so I didn't save that. I didn't check coords, but as mentioned I thought that was related to sketch information and IV usually tells me more about those errors.
Pete
Message 9 of 9
pkquat
in reply to: pkquat
I will give that a shot, and I can speculate to the cause of why that has an effect. This part was a living part as such. A base design that changed many times. I tried to keep the holes to keep the mates. How the part was defined changed often.
The 2.25 dimension changed a few times to a reference dim and back again. The 2.25 dim and the construction line it is tied to were indirectly related to the "pink dot". A dimension from projected geometry had controlled the location of the construction line. This dim also changed to and from a reference dim. At the time of the incident (lol) this dim was not reference and the 2.25 dim was a reference dim.
The part originally had a cut on the right side of the first sketch. This was removed and the lower line extended to the top. This also removed the projected line the construction line was dimensioned to and the caused the pink dot. The dimension to the construction line was deleted along with the projected line that had the pink dot. A new line was projected and the bottom dims recreated. The 2.25 was dim was changed from a reference dim to a real dim.
It shouldn't have an effect, but ya never know.
Pete
