Inventor Forum
My drawing hatch is so precise...
10 REPLIES 10
Message 1 of 11
Vlad.Makarov
1151 Views, 10 Replies
...I launch space ships with it.
______________
Inventor Pro 2012
Vault Pro 2012
10 REPLIES 10
Message 2 of 11
Vlad.Makarov
in reply to: Vlad.Makarov
Hmm, I guess I'm the only one whose Inventor gives wacky default hatch values?
______________
Inventor Pro 2012
Vault Pro 2012
Message 3 of 11
Talayoe
lol! I suppose you should charge extra for whatever that hatch is attached to and charge it out as 'extremely precision' or something of the similar.
Btw, I havent seen this on mine and use it all the time. It is quite funny tho 😉
-Randy
Inventor 2017 PDS
Message 4 of 11
trumpy81
Vlad, after using Inventor for a while and trying to track down reasons for assembly constraint failure, then numbers like that are common.
Why is Inventor so pedantic about numbers? .... lol
And Vlad, here's a challenge for you, try to measure that angle with your protractor .... lmfao!
Regards
Andy M
Autodesk Inventor 2013 Pro SP1.1, Win7 Pro - 64Bit - SP1, Intel i7 960 @ 3.333 GHz
Asus X58 Sabertooth, Corsair 12Gig DDR3, AMD Radeon HD6970, Samsung 830 Series 256G SSD, 2x 3TB Seagate, 2x 2TB Hitachi,
1x 1TB Samsung, 4 x 2TB Seagate in Netgear ReadyNAS NV+, Dual Asus VE278Q Monitors
Message 5 of 11
jozef.dubaj
Hi Vlad,
From where did you get the drawing? Created by you or received from someone? I\m curious whether did you enter value of 30 deg and then you found there 30.00022219255. Or you just received the drawing and check the hatching angle
-Jozef
Message 6 of 11
GSE_Dan_A
I win! This was from a hatching of a section I just made.  No changes made... straight from the Inventor Realm
GSE Consultants Inc.
Windsor, ON. Canada
Message 7 of 11
mrattray
in reply to: GSE_Dan_A
Did anyone notice that the error in those two hatch pattern are exactly the opposite? If you add them together you get 90.00000000000000.
Mike (not Matt) Rattray
Message 8 of 11
Hell-If-I-Know
in reply to: mrattray
What are the odds?
Message 9 of 11
Vlad.Makarov
in reply to: jozef.dubaj
@jozef.dubaj wrote:
Hi Vlad,
-Jozef
Hi Jozef,
The drawings are my own. I see the wacky values when I change the hatch style.
It is happening in section views of assemblies.
______________
Inventor Pro 2012
Vault Pro 2012
Message 10 of 11
moretti999
Volodya,
This is the value for Imperial degreesSmiley LOL
AM
Message 11 of 11
Rich.O.3d
in reply to: moretti999
First inventor converts the angle to radians then to fractional degrees then to decimal degrees, it then applies an analogous algorithm based on the colour of the 5th nearest star from earth multiplied by the deriviative of........
I get this too...it drives me nuts
Are you using a metric template, I am
I suspect that is where the issue comes from...inventor not quite knowing how to convert all the numbers properly so in the math that drives the auto hatch angle, there is a rounding issue.
CAD Management 101:
You can do it your own way,
If its done just how I say!
[Metallica:And Justice For All:1988]
