See comments below:
> My Documents=C:\Documents and Settings\Linnet\My Documents
> to the Workspace and see what happens.
Still tells me that the folder is read only . . .
> Are you able to save if you create and activate a new Project File?
> What is your Projects Folder set to (the place where the IPJ shortcuts are
> stored) in Tools->App Options->Files Tab?
> Have you read the IV7 File Management.doc in the /Documentation folder on
> the IV install disk?
Yes, several times.
> It seems to me that IV7 is very particular with its Workspaces-perhaps IV
is
> marking the parts internally as living in the Template directory (because
> the ipj has NO directories called) and since the "my documents" folder is
> obviously not a sub-folder, then it won't allow the save.
> myself at this point>
It seemed to me that the main advantage of having My Documents as the
Default location (at least I THOUGHT that's what Autodesk intended) was that
it is a relative statement - in this way any user that works in Inventor and
does not steer his files will, by default, place HIS/HER documents in
HIS/HER My Documents folder - an automatic project filing system that is
universal for all the users that use the same project file. Linnet uses the
"Default" project and her files go into Linnet\My Documents. Wesley later
logs on and uses the SAME "Default" project and his files automatically go
into "Wesley\My Documents". I _know_ how to create projects but thought the
Default project provided by Autodesk was supposed to actually _WORK_ .
Imagine the consternation at trying to tutor my son and finding that this
feature, out-of-the-box, does not work.
> I realize this sounds way out there in left field, but once you work in a
> semi-isolated project schema and see IV moving files AND directories
around
> all by itself, you start appreciating just how important these Project
File
> things are.
> I'm sure this problem can be sorted, more information may simply be
needed.
At this point I'm considering this a bug in Inventor at least back to IV6
SP1. Features out-of-the-box should work without any tweaking.
Do you have a "Default" project? What happens when you go to try to start a
new assembly, and then try to Create a component in that assembly? Does
Inventor go blonde on you too?
Thanks for the help!
Linnet
> QBZ
> "Linnet Mords" wrote in message
> news:A472423804F2E250EAC0E7A91E9D8C8A@in.WebX.maYIadrTaRb...
> > But the "out-of-the-box" Default project has no paths defined
whatsoever.
> > Indeed, I am not trying to edit a file, I am trying to create a new file
> > while in a new assembly. Whatsmore, if I explicitly add the
aforementioned
> > "My Documents" directory to either and both (in successive tries) the
> Local
> > and Workgroup paths in the Default project, the same error still
results!
