Hello All,
I am running 2014 Premium Design Suite on a Windows 7 64bit computer.
My Problem:
- I cannot see my assembly (I attached a screen shot of the assembly)
- It only is happing on this one specific assembly as other assemblies open no problem
- The Assembly tree shows that the parts are there
What I have tried that has not worked so far:
- Lots of Googling for an answer
- Rebuild All Command
- Tried opening it on another computer
- Made sure all of the parts are checked visible
- Looked to see if the visual settings were effecting it
Any help would be greatly appreciated.
Thank you,
Jeff
Solved by JDMather. Go to Solution.
I had something similar happen once. it would appear in other view reps but not the default. What I did was create a new view representation, name the original default to something else and name the new view rep default. Then deleted the original "default" view rep. It was as if the view rep got corrupted somehow.
Don't know if that's your problem here, but just throwing it out there.
Have you closed/restarted Inventor?
Rebooted computer?
What if you change tools..application options..hardware tab to "compatibility mode" or "use software graphics"
Have you made sure your graphics card driver is up to date? what card? what driver version?
Suppress all but one part and then do a Zoom All.
Does that one part suddenly appear?
My guess is that the bounding box size of one part is corrupt or you have a floater out in space.
Are any of your files imported from IGES or STEP or other?
It could be a couple of other problems as well.
I have to go do my real job for a while, then I will come back with some things to try if someone else hasn't jumped in here.
Right mouse click on a component and select Suppress from the context menu.
Edit: Suppress means suppressing components not needed for the current task. When suppressing in assemblies, you will create level of details (LODs): http://help.autodesk.com/view/INVNTOR/2016/ENU/?guid=GUID-BB22DDCB-F370-4BF0-B438-EC1D0E91D49E. In this case suppressing the components at JD has pointed out may resolve a given component boundry box issue or that you have a component floating out in space which would cause the model to appear small.
Mark Lancaster
& Autodesk Services MarketPlace Provider
when I drew drafting detail in revit 2017 suddenly the rivet closed. when I opened it the detail disappeared. Do you have any experience how to fix it?
I don't have any experience drawing rivets in Revit.
