Inventor General Discussion
akosi
Message 1 of 7 (495 Views)
multiple sheets for idw
495 Views, 6 Replies
10-01-2010 06:01 AM
hi,
i have an assembly with 100+ parts that i have to show in my parts list.
my question is :
how can i add identical sheets showing identical view of the assembly but the ist page will show the first 50 parts and the second page will show the rest of the part list?
thanks
inventor 2011
vault 2011
Copy the view from Sheet 1 to Sheet 2.
Place a parts list on each sheet and edit to turn off visibility.
Mike
Mike_Maenpaa
Message 2 of 7 (488 Views)
Re: multiple sheets for idw
10-01-2010 06:13 AM in reply to: akosi
Mike
akosi
Message 3 of 7 (481 Views)
10-01-2010 06:35 AM in reply to: Mike_Maenpaa
awsome!!!  :smileyhappy: ... thanks
Active Member
mirzanasrullah
Message 4 of 7 (232 Views)
03-30-2013 07:40 AM in reply to: akosi
Dear All,
Please i want to know that - Can it be possible to make the single template or prompted values for my multiple sheet.
this is to avoid the time to complete each sheet for prompted text and to make unified sheet for one perticular part or assembly.
Thank you.
Nasrullah Baig Mirza,
Mechanical Design Engineer,
Active Member
mirzanasrullah
Message 5 of 7 (164 Views)
05-13-2013 05:59 AM in reply to: mirzanasrullah
Please help for the above query... Still waiting...
Valued Contributor
mikejones
Message 6 of 7 (161 Views)
05-13-2013 06:07 AM in reply to: mirzanasrullah
Try changing the prompted entries in your title block definition to use iProperties or custom iProperties instead. This way the iProperties will appear on all sheets automatically.
Mike
Autodesk Certified Professional
sam_m
Message 7 of 7 (156 Views)
05-13-2013 06:14 AM in reply to: mirzanasrullah
toggling the visibility for each line-item is kinda crazy.  A better way would be to use the filter option to, erm, filter the parts lists to the first x components and then copy the sheet and change the filter range to start with the next item to the end.
As for setting up a template to have this already setup, dunno if it's needed as it's only a 5second job to assign a filter (compared to the time for toggling half the parts list visible or not).
as for a separate sheet for each part, etc.  just use 1 idw for each part or assembly, as it's really intended to be used...
Please mark this response as "Accept as Solution" if it answers your question...
but please understand that the solution may not be the answer you're wanting to hear...
If you have found any post to be helpful, even if it's not a direct solution, then please provide that author kudos - spread that love :smileyvery-happy:
Lithium - helping nntp users with mania, depression and headaches
