I am new to Inventor. I am trying to flatten a shell. It is pressure vessel component. I can rip it and unfold just fine, but the final part, when built, is too big to mfg in one piece. I noted that multiple rips are supported and I can do two rips fine. I basically have a top half and bottom half. But when I flatten it, one half is missing. I stumbled upon "unfold". I can do that to both halves and have them as flat plates seperated in space in one .ipt. . If I try to create 2D drawings, one half is missing. I can't find it to create projections in a dwg. I've assumed this might work better if I created an assembly of the 2 halves, but haven't been able to erase half as ripped and save as(pt1, pt2), to create the two parts to the assy. Any ideas?
Solved by rsgallo. Go to Solution.
I would do Derived Components to get the flats.
I tried your suggestion. It still treats the model as one part, even though it is ripped into two parts. I could not derive one half from the other. I've included the part file for perusal. Am I missing something?
JD is suggesting tha youuse your origional part as a master part, which will control two derived parts.
Create the split in your master part - being caerful to make sure that you chose the 'New Body' option.
Now use the make components tool to create two derived parts, each containing a reference to your origional master part.
Each of these parts should flattern sucessfully.
please refer to the attachment.
I have just followed the previous 2 peoples instructions.
I gather I should use "split" with the model, instead of "rip" as a sheet metal function. I tried that, but when I attempt to derive parts, or make component, there is still only one solid available and it is the total model.
rageshindi, I cannot open the file you sent back. A dependent file is missing.
Nothing you have done makes sense to me?
I would start over using obvious symmetry about the origin
see http://home.pct.edu/~jmather/skillsusa%20university.pdf
your first sketch isn't constrained and it looks like you are doing too much work
(see attached)
This is a good example of why Inventor Fusion should never have seen the light of day.
It is true the drawing was cluttered with various trial and error. I need to learn more about drawing constraints.
I had some phone support due me on my upgrade purchase, so I called. Nothing wrong with my file. Yes, it is "spit" in the model space, not "rip" in sheetmetal. After splitting, then one must "manage"> "make component". The halves must be selected to show up in the Make Components window. This is what I was missing. I saw none or one solid and had no idea what to do. Thanks for your help.
In addition to getting the sketches constrained/dimensioned - also take a look at how the holes were placed in the inclined plane (check in derived flat pattern). They are not perpendicular to the face as is.
