Hi 3DAli,
You can turn on the text box for your text field in the title block and dimension to it, in order to set the field up to wrap properly. Attached is an example IDW to look at as well.
I hope this helps.
Curtis
Echoing greg.h's question:
Is there any way to insert a Newline character into an Iproperty in Inventor?
We wish to have a 3 line description and be able to dictate where the Line breaks are ie
Transformer
440V In
240V Out
Transformer
440V In
240V Out
Unless something changed in the last few releases and went undocumented then no...you still can't dictate where the breaks are BUT..
You could just use 3 custom iprops..
Line 1
Line 2
Line 3 or whatever..
They are all multi-line but iProp window is showing just last line; more details.
