Inventor Forum
Multiple line text in iProperties?
7 REPLIES 7
Message 1 of 8
kennedgy
2670 Views, 7 Replies
Is it possible within Inventor to create multiple line text for an iProperty?
I have seen an iProperties editor add-on that includes the feature, but it seems there should be a way to do it within Inventor.
Thanks.
7 REPLIES 7
Message 2 of 8
mcgyvr
in reply to: kennedgy
In my title block I have a section for description (taken from the description iprop) it will automatically wrap to the next line when the text exceeds a certain length... But that's about it.
Message 3 of 8
3DAli
in reply to: mcgyvr
Hi there,
I have difficulty to make a section in my title block with that auto wrap feature, how do I do that?
Signature_Small
Message 4 of 8
Curtis_Waguespack
in reply to: 3DAli
Hi 3DAli,
You can turn on the text box for your text field in the title block and dimension to it, in order to set the field up to wrap properly. Attached is an example IDW to look at as well.
I hope this helps.
Curtis
Message 5 of 8
3DAli
in reply to: Curtis_Waguespack
Thank you sooooo much. you are great, I really enjoy being part of IV family, I believe what we have here is a great culture of helping each other out when it comes to it and this is absolutely a differentiator.
All the best
Ali
Signature_Small
Message 6 of 8
Emerson717
in reply to: mcgyvr
Echoing greg.h's question:
Is there any way to insert a Newline character into an Iproperty in Inventor?
We wish to have a 3 line description and be able to dictate where the Line breaks are ie
Transformer
440V In
240V Out
Message 7 of 8
mcgyvr
in reply to: Emerson717
Transformer
440V In
240V Out
Unless something changed in the last few releases and went undocumented then no...you still can't dictate where the breaks are BUT..
You could just use 3 custom iprops..
Line 1
Line 2
Line 3 or whatever..
Message 8 of 8
salariua
in reply to: mcgyvr
They are all multi-line but iProp window is showing just last line; more details.
Adrian S.
blog.ads-sol.com
AIP2012-2020 i7 6700k AMD R9 370
Did you find this reply helpful ?
If so please use the Accepted Solutions or Like button - Thank you!
