Only found 1 message about this, was 5 years old, and a dead end after 2 posts.
Can you have multiple languages in a drawing? Text and dimensions? (having the "alternate unit" to be a different language would be ideal)
-Tom
The short answer is "No". The language is set on the install. Now, you can always search the ideas in the Inventor IdeaStation
and if you do not find a language idea that speaks to this you can create your own.
Also, you can always use Google translator and paste from there into the drawing text editor to sort of accomplish this from a note stand point.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
