Inventor General Discussion
Active Member
mariox
Message 1 of 6 (48 Views)
Multiple items insertion
48 Views, 5 Replies
12-05-2002 07:00 PM
Hi everybody, everything's OK?. Do anybody else can help me resolving this problem? I will like to insert a bolt, washer, nut, ecc. and constraint once each time, but I wish a detailed parts list of the final assembly, detailing any single bolt, washer, ecc.
Thanks for your brain time, thanks for readig.
AOG
Giovanni
*Keller, Kent
Message 2 of 6 (48 Views)
Re: Multiple items insertion
12-06-2002 01:33 AM in reply to: mariox
Not sure I understand, but can you make the bolt, washer, and nut a sub assembly to cut
down on the constraints needed each time?
Kent
Member of the Autodesk Discussion Forum Moderator Program
"mariox" wrote in message news:f12a262.-1@WebX.maYIadrTaRb...
> AOG
> Giovanni
Active Member
mariox
Message 3 of 6 (48 Views)
Re:
12-08-2002 06:42 PM in reply to: mariox
Yes, I will like to insert an assembly, but when I make the parts list, I will like a detailed parts list specifying both the bolt, nut, washer, ecc. Instead, the program specify only the sub assembly with the name I gave it.
Thanks a lot Kent
*Maas, Karl
Message 4 of 6 (48 Views)
Re:
12-08-2002 10:08 PM in reply to: mariox
When you first insert your parts list, you have the
option to show top level parts only or ALL parts.
K
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
Yes,
Thanks a lot Kent
Active Member
mariox
Message 5 of 6 (48 Views)
Re:
12-08-2002 10:34 PM in reply to: mariox
Ok, it does work, but now there are a lot of items that belong to other sub assemblies and should not appear in the parts list, thanks again and again.
*Keller, Kent
Message 6 of 6 (48 Views)
Re:
12-09-2002 01:07 AM in reply to: mariox
Yes, unfortunately you have to hide each of those unwanted rows in the list.
Kent
"mariox" wrote in message news:f12a262.3@WebX.maYIadrTaRb...
