Inventor Forum
Multiple items insertion
5 REPLIES 5
176 Views, 5 Replies
Hi everybody, everything's OK?. Do anybody else can help me resolving this problem? I will like to insert a bolt, washer, nut, ecc. and constraint once each time, but I wish a detailed parts list of the final assembly, detailing any single bolt, washer, ecc.
Thanks for your brain time, thanks for readig.
AOG
Giovanni
5 REPLIES 5
Not sure I understand, but can you make the bolt, washer, and nut a sub assembly to cut
down on the constraints needed each time?
Kent
Member of the Autodesk Discussion Forum Moderator Program
"mariox" wrote in message news:f12a262.-1@WebX.maYIadrTaRb...
> AOG
> Giovanni
Yes, I will like to insert an assembly, but when I make the parts list, I will like a detailed parts list specifying both the bolt, nut, washer, ecc. Instead, the program specify only the sub assembly with the name I gave it.
Thanks a lot Kent
When you first insert your parts list, you have the
option to show top level parts only or ALL parts.
K
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
Yes,
Thanks a lot Kent
Ok, it does work, but now there are a lot of items that belong to other sub assemblies and should not appear in the parts list, thanks again and again.
Yes, unfortunately you have to hide each of those unwanted rows in the list.
Kent
"mariox" wrote in message news:f12a262.3@WebX.maYIadrTaRb...
