Follow this link; hint, hint, wink, wink.
http://www.mcadforums.com/forums/viewtopic.php?p=47733#47733
Duncan
"Humour ... is one man shouting gibberish in the face of authority, and proving by
fabricated insanity that nothing could be as mad as what passes for ordinary
living."
(Terence 'Spike' Milligan K.B.E., 1918-2002)
www.autodesk.co.uk/inventorjobs
"Gary Tafoya (Autodesk)" wrote in message
news:5390930@discussion.autodesk.com...
Gents,
Make sure that you sign up and check out the beta for our next release as
Sam Antos pointed out in an earlier post.
Hint, hint, wink, wink.
Thanks!
Gary Tafoya
Inventor Assembly Quality Assurance
"Duncan Anderson"
wrote in message news:5390767@discussion.autodesk.com...
Inv is/has an MDI, multiple display interface, eg. you can have one instance
of Inv
open and multiple files open within that one instance.
Inv comes with the functions Save All & Close All.
But you try opening more than one file at a time ! ! !
It should be possible with the File Open dialogue to use window select,
Ctrl+select
or Shift+select to open multiple files in one go.
The best I can do at the moment is use Win Explorer - or Search - and drag
them
into Inv.
I assume this is because earlier versions of Inv would have crashed if too
many
files were opened, but Inv's performance seems better now.
[growling, wailing and gnashing teeth]
Duncan
proving by
living."
