Inventor Forum
Multiple faces with thread command
2 REPLIES 2
594 Views, 2 Replies
This may be a simple question, forgive me. Is it possible to pick more than one face at a time when using the thread command? i have six holes all the same size that i want to apply the same NPT size to. thanks.
2 REPLIES 2
For Thread you are only able to select a Face,
which is only one Face.  You may investigate creating an iFeature of
the Extrusion with the Thread, or simply use the Hole feature.  The Hole
feature lets you create multiple Threaded holes at one time.
Jeff
This
thanks.
But only on the same sketch which by definition is
planar so you won't be able to select multiple faces this way
either.
Sean Dotson, PE
href="http://www.sdotson.com">http://www.sdotson.com
Check the Inventor
FAQ for most common questions
href="http://www.sdotson.com/faq.html">www.sdotson.com/faq.html
The Hole feature lets you create multiple
