Inventor Forum
multiple extrusions from one draw plane?
14 REPLIES 14
Message 1 of 15
donovandigital
34333 Views, 14 Replies
That is to say, more than one closed shape on the same plane.
Is it possible? If so, how?
Thanks much in advance
Joe
Tags (1)
14 REPLIES 14
Message 2 of 15
cwhetten
in reply to: donovandigital
Do you mean multiple extrusions from one sketch?  This is certainly possible.  After your first extrusion, right-click on the sketch and select Share Sketch.  This makes it available to be used by further features.
If you just mean multiple extrusions from one work plane, then there is no limitation on the number of features that can reference a work plane.
Message 3 of 15
JDMather
If you can't figure it out - attach your file here.
Message 4 of 15
donovandigital
in reply to: cwhetten
works like a dream - awesome! Probably my biggest peeve since I started.
Only thing, option is not available in some cases. Why is that?
Thanks again
Joe
Message 5 of 15
JDMather
Attach file here that exhibits this behavior.
Message 6 of 15
donovandigital
in reply to: JDMather
Not sure how well that will work - it depends on which level of the hierarchy is active. Not a major deal, as I can just click around until the right object is active.
Just curious - what is the logic behind this "consumed" sketch business? Surely autodesk don't think that most people will only have one extrusion/revolution per plane?
Message 7 of 15
JDMather
I don't follow the logic of your statement.  Attach example file here.
Are you really referring to sketches?
Message 8 of 15
donovandigital
according to http://wikihelp.autodesk.com/Inventor/enu/2012/Help/0073-Autodesk73/0308-Parts308/0353-Part_fea353/0...
"For parts, surface features and work features are automatically consumed by default to communicate feature dependencies." - What do they mean, feature dependencies? Most of the time, I want to draw separate features on the same sketch. Why is it that by default they are consumed?
I can post if you really want, how would you like me to package? Zip?
Message 9 of 15
JDMather
Go through this paper
http://home.pct.edu/~jmather/skillsusa%20university.pdf
go through this tutorial (the sketches are already done (see attached) - you might start a new part file and see if you can create them from scratch
http://home.pct.edu/~jmather/content/DSG322/Inventor%20Tutorials/Inventor%202011%20Tutorial%2014.pdf
Message 10 of 15
JDMather
oops, here is the file attachment.
Message 11 of 15
JDMather
Based on the sketches in this thread
http://forums.autodesk.com/t5/Autodesk-Inventor/best-option-for-a-custom-eyebolt/m-p/3337965#M426394
I recommend that you post everything you do for a while to see how others might have done the geometry.
Message 12 of 15
The attached screen shots should help you understand dependencies. Drawing separate features on the same sketch is not always a good idea. It depends on the complexity of what you're creating. Sometimes it is best to make simple sketches & build from there using geometry projection.
Message 13 of 15
donovandigital
JD
Sorry for the late reply, I didn't see your response til now.
I would definitely like to post my work; how would you recommend I do this - start a new thread or use this one?
Thanks again
Joe
Message 14 of 15
JDMather
Start a new thread.
Request review of technique and alternative methods.
Message 15 of 15
It may be due to that while you are in the sketch environment, your options are limited. Try ending the sketch and there should be more options
