Inventor General Discussion
Valued Contributor
donovandigital
Message 1 of 14 (2,650 Views)
multiple extrusions from one draw plane?
2650 Views, 13 Replies
02-17-2012 09:38 AM
That is to say, more than one closed shape on the same plane.
Is it possible? If so, how?
Thanks much in advance
Joe
Do you mean multiple extrusions from one sketch?  This is certainly possible.  After your first extrusion, right-click on the sketch and select Share Sketch.  This makes it available to be used by further features.
If you just mean multiple extrusions from one work plane, then there is no limitation on the number of features that can reference a work plane.
works like a dream - awesome! Probably my biggest peeve since I started.
Only thing, option is not available in some cases. Why is that?
Thanks again
Joe
cwhetten
Message 2 of 14 (2,646 Views)
Re: multiple extrusions from one draw plane?
02-17-2012 09:53 AM in reply to: donovandigital
JDMather
Message 3 of 14 (2,638 Views)
02-17-2012 11:15 AM in reply to: donovandigital
If you can't figure it out - attach your file here.
Autodesk Inventor 2015 Certified Professional
Inventor Professional 2015-SP1 64-bit
Valued Contributor
donovandigital
Message 4 of 14 (2,631 Views)
02-17-2012 12:02 PM in reply to: cwhetten
Thanks again
Joe
JDMather
Message 5 of 14 (2,626 Views)
02-17-2012 12:05 PM in reply to: donovandigital
Attach file here that exhibits this behavior.
Valued Contributor
donovandigital
Message 6 of 14 (2,618 Views)
02-17-2012 12:15 PM in reply to: JDMather
Not sure how well that will work - it depends on which level of the hierarchy is active. Not a major deal, as I can just click around until the right object is active.
Just curious - what is the logic behind this "consumed" sketch business? Surely autodesk don't think that most people will only have one extrusion/revolution per plane?
JDMather
Message 7 of 14 (2,612 Views)
02-17-2012 12:23 PM in reply to: donovandigital
I don't follow the logic of your statement.  Attach example file here.
Are you really referring to sketches?
Valued Contributor
donovandigital
Message 8 of 14 (2,607 Views)
02-17-2012 12:31 PM in reply to: JDMather
according to http://wikihelp.autodesk.com/Inventor/enu/2012/Help/0073-Autodesk73/0308-Parts308/0353-Part_fea353/0...
"For parts, surface features and work features are automatically consumed by default to communicate feature dependencies." - What do they mean, feature dependencies? Most of the time, I want to draw separate features on the same sketch. Why is it that by default they are consumed?
I can post if you really want, how would you like me to package? Zip?
JDMather
Message 9 of 14 (2,582 Views)
02-17-2012 02:43 PM in reply to: donovandigital
Go through this paper
http://home.pct.edu/~jmather/skillsusa%20university.pdf
go through this tutorial (the sketches are already done (see attached) - you might start a new part file and see if you can create them from scratch
http://home.pct.edu/~jmather/content/DSG322/Inventor%20Tutorials/Inventor%202011%20Tutorial%2014.pdf
JDMather
Message 10 of 14 (2,575 Views)
02-17-2012 03:14 PM in reply to: JDMather
oops, here is the file attachment.
