Is it possible to set up several views that show the model in real-time as you are working on it? (Be it by using views, seperate windows or the like?)
I'm imagining something like the screen being split into quarters, with one showing plan view, one side view, one front view and one isometric, showing what I am doing to my model in their respective window.. I'm sure I've used a CAD package (rhinocerous?) where this was the case...
..Can this be done in Inventor?
Jamie
Solved by Mike_Maenpaa. Go to Solution.
Yes. See attached.
Views Tab > New Window
Then Tile Windows
Use the View Cube to set the desired orientation of the model in each window.
Mike
