You should save to the Workspace (it should do this by default). When you
check-out parts, IV makes a copy of part on your local (workspace). This is the
file you want to update. When you check-in, IV overwrites the file in the
Workgroup. In the meantime, others can LOOK at the file you are altering, but
not save to it. When you are done, check-in all files you have checked-out
(usually "check-in tree") then close. You don't save again after you check-in.
Dave Jacquemotte
Automation Designer
