I am using Inventor 2014. I want to know if I can create a multi-draft like in the PDF or do need to sweep this. It drafts from the center out.
Solved by Cadmanto. Go to Solution.
Solved by JDMather. Go to Solution.
I think you will have to do that as a Loft
or
a variable radius fillet, Delete Face the fillet and Patch.
The CADWhisperer YouTube Channel
I would create it as a sweep with profiles at each of the transitions and possible multiple guide curves.
I would stay away from the variable fillet. It looks too square to be able to use the fillet command.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
