I am creating a multibody part. I have revolded a surface from a sketch through other bodies and used those bodies to trim the surface. I then thicken the surface to create a solid.
The solid is transparent and no amount of property adjusting or anything else will make it opaque like the rest of the solids.
in the picture the open scalloped portion contains two bodies.
Any thoughts?
Can you send me the file jmather_at_pct_dot_edu or attach it here?
Had you at any time change the properties of any body to one of the transparent colors?
jd,
thanks for the offer. I recreated the entire .ipt. i was not that far along. No issues this time. I believe it was operator error
of some fashion. I did not save the old file unfortunately
