Hi
I have a pressure gauge i want to model.I could make the parts separately and assemble or make as a single part but with multi-bodies.The gauge will only have the visible parts modelled (not the internal mechanism).....There is 6 parts.....is there any advantage with one over the other......the gauge will go into a larger assembly to show its position in the process...
Thanks for any advise
James
Every strategy have pro and cons.
Your assembly have a verry little amount of parts, only 6. In this case you can go fast in any case.
With multibody you will not use constraint, you will have a good flexibility and high level of editing and mostly you will have in any moment geometry parts references to take profit by, without the risk of adaptive parts.
Admaiora
Have a look at the option to "push" out the multi-body solid into derived individual parts and an assembly. "Make Component" or the button next to it off the top of my head.
Personally I really like multi-bodies, just a pity no sheet metal. I find them faster for design work and cabinet making. But for draughting I usually use the bottom-up approch.
Hi Barry,
That's a really intriguing statement. Would you mind expanding on your technique a little?
Could you give us an example of a 'Drafting' project?
Paul
Sure thing, but forgive my grammar at the moment. I came back from 10 weeks of contract work in West Africa with Malaria
Here is my award-winning table 🙂 modelled up as 5 solids and with the solids renamed to my preferance. I have selected "make component" and selected which (all) of my solids from the browser that I need. By default the "insert components in target assembly" is ticked.
Next screen, my solids names have been copied across and I am going to leave them as such.
And there we have it! My super-stylish table as an assembly with each solid spat out as a new .ipt. The only thing it dosen't have is constraints, everything gets grounded and rooted. All the .ipt's are derived, so I am sure any edits to the original multi-body file will filter through.
Hi! Inventor's multi-solid body worklfow can be considered an extension to skeletal modeling workflow. Basically, you create geometry within a part. Then use Make Components or Make Part command to push each solid body as an individual part in an assembly.
If you do not care about material variation, BOM table, reusing component definition and you only care about geometry, modeling an assembly in a multi-solid part and keeping it as is could be very convenient.
Thanks!
