First of all, I'm on IV2009.
I've got a drawing file of an iPart family that I made. I dimensioned the first part in the group, then I change the model state to view the correspondingh dimensions of the other parts in the family. However, I have run into a problem with a dimension moving when I change the model state. I have an angular dimension that will move laterally on the drawing sheet, often to the very edge of it. This only happens with the angular dimension though. I have several linear dimensions that stay in the same place. What could be the problem behind this?
Attached are images showing the issue.
