Inventor Forum
moveable links
7 REPLIES 7
Message 1 of 8
sam__gleeson
456 Views, 7 Replies
moveable links
I have a link.. How do i mate these links together so as the chain is moveable in all directions..
SAm
7 REPLIES 7
Message 2 of 8
JDMather
in reply to: sam__gleeson
How many total links?
Contact sets might work for a few links
mated workpoints will allow more links, but restricts some of the DOF
Dynamic Simulation could be an option, but again - more than a few links is going to drag your machine to it's knees.
What is your true design intent.
The more DOF you can remove the easier for the computer to solve.
Message 3 of 8
sam__gleeson
in reply to: JDMather
approx, 30 links per chain
A steel box with a chain on each corner connecting to a larger ring...actually does not need to move....i need to make 4 chains (each 30 links) .. each chain attaches to a corner on the steel box and then all 4 chains held together a the top on a large ring
Sam
Message 4 of 8
JDMather
That description sounds like all DOF can be removed.
Place workpoints where the insides of the links would be tangent (tangent constraint would be more complex than needed.
Constraint the workpoints.
Add constraints to origin workplanes between links to make them perpendicular to each other.
I would probably simplify by pattern Feature as body in single part rather than do these as individual parts.
Message 5 of 8
sam__gleeson
I followed your advice and came up with these files.
How do i progress to the following
1. adding the 4 chains to the links on the frame and then the chains connected on to the centre Ring
Regards
Sam
Message 6 of 8
sam__gleeson
Hi
need help with ;last stage of adding the chains to the bracket and ring.Anyone?
Thank you
Message 7 of 8
sam__gleeson
Hi
I am having trouble getting the 4 chains to connect to the ring.Can someone help me out here please?
Sam
Message 8 of 8
sam__gleeson
someone/anyone.I need help placing the chains onto the frame and ring.I have tried but it is not working.Please help
Sam
IV 2013 EDU
