You can't just move it, you should make a work plane on the place where you want it. then create your sketch.
He´s right, you´re going to need a workplane.
You can also try to redefine your existing sketch to that workplane.
But i think in thiscase it´s easier to redraw the sketch in the right
position.
Kind regards
Daniel
Shouldn't need any extra workplanes - attach your ipt file here.
The CADWhisperer YouTube Channel
I wanted to move it to the center so I could make an extrude cut. I realized since it's solid of course it would cut all the way through and not just little bit all the way around. The work plane hint helped.
