Inventor General Discussion
mns3fa
Message 1 of 16 (244 Views)
Move rectangular pattern
244 Views, 15 Replies
03-03-2014 02:40 PM
I'm trying to move a rectangular pattern as a whole in a certain direction. I tried to click on move bodies, but it won't let me just select a particular rectangular pattern.  Any idea how to do this?  Thanks!
Sketch8 is not fully constrained and why multiple lines for one line?
You circle profile is not connected to your path.
Edit Sketch 9 and Project Geometry select the line close to the circle in this image.'
Add a coincident constraint between the circle center and the point projected from the path.
JDMather
Message 2 of 16 (239 Views)
Re: Move rectangular pattern
03-03-2014 03:04 PM in reply to: mns3fa
Attach your *.ipt file here.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015-SP1 64-bit
mns3fa
Message 3 of 16 (235 Views)
03-03-2014 03:07 PM in reply to: mns3fa
Here's the file
JDMather
Message 4 of 16 (233 Views)
03-03-2014 03:20 PM in reply to: mns3fa
Why did you start a new thread?
Is something like this what you are after?
mns3fa
Message 5 of 16 (198 Views)
03-04-2014 09:22 AM in reply to: mns3fa
Yes it is!  How do I go about doing that?
mns3fa
Message 6 of 16 (196 Views)
03-04-2014 09:41 AM in reply to: mns3fa
More specifically, in your file, how did you start sketch 2 where you started it?
mcgyvr
Message 7 of 16 (189 Views)
03-04-2014 10:02 AM in reply to: mns3fa
He just make 2 sketches..then performed sweeps/rectangular patterns..
Each sketch contains the path for one direction and the profile for the other.. Both sketches are shared so they can be used (consumed) over and over again
2015 Product Design Suite Ultimate
Windows 7 64 bit
Core i7 4820k processor (OC'd to 4.4Ghz), Nvidia GTX 770, 16G RAM
mns3fa
Message 8 of 16 (182 Views)
03-04-2014 10:18 AM in reply to: mcgyvr
Okay, I made my 2 sketches, but now I'm trying to sweep, and I can't draw a circle for the profile like I was able to before, because now the center of the circle is not on the origin
JDMather
Message 9 of 16 (179 Views)
03-04-2014 10:25 AM in reply to: mns3fa
Perhaps the most important part of learning Inventor is how to read the sketch/feature history tree.
Drag the red End of Part marker up the history tree to just below the Sketch2.
Right click on Sketch1 and turn on Visibility of the sketch, repeat for Sketch2.
Right click on the XY plane and turn on Visibility, repeat for the YZ plane.
Drag the red EOP down one step.
Drag the EOP down to the next step.
Right click on the Pattern feature - notice that I set to do a midplane pattern....
Use symmetry to reduce work.  Use symmetry about the origin planes.
Use symmetry.
You might read this document http://home.pct.edu/~jmather/SkillsUSA%20University.pdf
Did I mention - get lazy - use symmetry.
JDMather
Message 10 of 16 (178 Views)
03-04-2014 10:26 AM in reply to: mns3fa
Once again, attach your file here.  If a picture is worth a thousand words, the actual geometry might be worth 10,000 pictures.
