I have a file that came from a CT scan. The problem is that the zero point is not in the center. Is it possible to move the object to the center?
Solved by Curtis_Waguespack. Go to Solution.
Can you post the file here, or a screen shot? What kind of file is it?
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Hi j.mulder,
You can try the suggestion as this link:
http://inventortrenches.blogspot.com/2011/06/change-origin-of-imported-model.html
If that doesn't work, then as cbenner suggests, you might provide a screenshot or further details.
I hope this helps.
Curtis
Good post! I've never needed to do this, but now if I ever do I know a good reference. Learn something new every day!
Chris Benner
