Inventor Forum
move object
3 REPLIES 3
446 Views, 3 Replies
move object
I have a file that came from a CT scan. The problem is that the zero point is not in the center. Is it possible to move the object to the center?
3 REPLIES 3
cbenner
Curtis_Waguespack
Hi j.mulder,
You can try the suggestion as this link:
http://inventortrenches.blogspot.com/2011/06/change-origin-of-imported-model.html
If that doesn't work, then as cbenner suggests, you might provide a screenshot or further details.
I hope this helps.
Curtis
cbenner
in reply to: Curtis_Waguespack
