Inventor General Discussion
Member
0 Kudos
Post 1 of 8
Move multiple dimensions from one view to another in drawing
649 Views, 7 Replies
06-05-2012 10:27 AM
Did a cursory search, did not find exactly what I'm trying to do.
I found that I can right click a dimension in a drawing and select "Move Dimension" which then prompts me to select an alternative view in which I want the dimension placed. Is it possible to control-click multiple dimensions once to do this all in one fell swoop (e.g. I decided my view is too busy and want to move dimensions to a newly created detail view of that area)?
Thanks!
James
message edit: I'm using Inventor 2010
looks like you have to select one dimension at a time
I would need to make a video to explain but my tip loses appeal for users on 2010 because in 2010 we could not reorient an existing view.
The main point I wanted to make is that you don't have a window select for moving dimensions but there is a window select when deleting dimensions.
My thought was to copy the view and all its dimensions first in order to benefit from the window delete capability. That is all I wanted to point out.
I don't think there is an elegant solution to this problem.
Bob
Distinguished Mentor
33 Kudos
Post 2 of 8
Re: Move multiple dimensions from one view to another in drawing
06-05-2012 10:37 AM in reply to: jamesluntz
Inventor 2010 Certified Professional
Product Support
47 Kudos
Post 3 of 8
06-06-2012 02:21 PM in reply to: swordmaster
If you have a ton of existing dimensions in a view and you don't want to move dimension per dimension, consider following workflow
1. Copy and paste the view on the same sheet
2.Rotate the copy or use this button in Edit view (depending on the view you want to obtain)
3.Align the copy to the original view if necessary
4. Remove redundant dimensions with window select
Bob
1,702 Kudos
Post 4 of 8
06-06-2012 02:48 PM in reply to: bobvdd
Hi bobvdd,
Just to avoid confusion, jamesluntz indicated he is using Inventor 2010, and therefore won't be able to use the tools you suggest.
Also, I'm not following the tip you provided. If you have time can you clarify a bit?
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
Product Support
47 Kudos
Post 5 of 8
06-06-2012 02:54 PM in reply to: Curtis_Waguespack
Bob
1,702 Kudos
Post 6 of 8
06-06-2012 03:11 PM in reply to: bobvdd
Hi bobvdd,
Thanks for the clarification, that makes sense to me now.
Curtis
New Member
0 Kudos
Post 7 of 8
05-02-2014 03:04 AM in reply to: Curtis_Waguespack
I guess my problem is a little different than the topic here.. the question is, can we move dimensions in between 2 views, of different file types(.iam and .ipt) which are geometrically identical.
The background story is that, we are replacing the .iam file with its derived .ipt file..
So, can’t replace the link in the assembly drawing, as they are of different file types..
So, there are 2 views which are geometrically identical but of different file types, can we move the dimensions from one view to the other(.iam to .ipt).. And there are a huge no. of drawings with similar change...
I come up with these weird problems, all the time... :smileyhappy: :smileyhappy:
Please let me know, if there is a way..
Jebaz.
Product Support
47 Kudos
Post 8 of 8
05-02-2014 11:38 AM in reply to: Jebaz.santosh
Can you not place the derived ipt in a new assembly?
And use that new assembly in the "Replace model reference" command?
Bob
