In doing a move face I noticed there isn't any parameters that can be edited after the move face has been created. I want to control the face length with a parameter after it has been created. Am I missing something or is there a work-a-round?
Thanks in advance
Solved by Curtis_Waguespack. Go to Solution.
Hi meck,
If you switch from the Free Move method to the Direction and Distance method, I think you'll get the parameter input you're looking for:
http://wikihelp.autodesk.com/Inventor/enu/2013/Videos/Move_Faces_by_Direction_and_Distance
I hope this helps.
Curtis
That was it!
Thanks!
