Inventor General Discussion
Active Member
smithme1967
Message 1 of 6 (3,563 Views)
Move detail view to a different sheet in Inventor 2009
3563 Views, 5 Replies
05-14-2010 01:12 PM
How can I move a detail view to another sheet in a drawing in 2009? I have only been able to copy the detail and it's parent view to the 2nd sheet and then suppress the parent view on the 2nd sheet so that only the detail view is visible. However, when I go back to the first sheet and try to suppress or delete the detail view, it also deletes/suppresses the detail circle from the parent view.
mcgyvr
Message 2 of 6 (3,563 Views)
Re: Move detail view to a different sheet in Inventor 2009
05-14-2010 01:23 PM in reply to: smithme1967
I forgot how it works in 2009 (might/should be the same) but with 2011 you simply drag the detail view (from the model browser) down to the sheet you want it on. You have to make sure that the sheet that the detail is on (when you start) is the active sheet.
2015 Product Design Suite Ultimate
Windows 7 64 bit
Core i7 4820k processor (OC'd to 4.4Ghz), Nvidia GTX 770, 16G RAM
Active Member
smithme1967
Message 3 of 6 (3,563 Views)
05-14-2010 01:30 PM in reply to: smithme1967
That worked, thank you!
Valued Mentor
Ktelang
Message 4 of 6 (3,535 Views)
09-23-2010 07:49 AM in reply to: smithme1967
Thats to both of you this thread helped  :manvery-happy:
Config :: Intel (R) Xeon (R) CPU E31245 @ 3.30 GHz, 16.0 GB, 64bit win7
Inventor 2013 and Vault Basic 2013
Member
c.vasquez
Message 5 of 6 (2,831 Views)
06-27-2012 08:26 AM in reply to: smithme1967
Cant get this trick to work in Inventor 2013! It wont allow me to drop thedetail view on the new sheet. Please advice
Carlos
Member
c.vasquez
Message 6 of 6 (2,826 Views)
06-27-2012 08:39 AM in reply to: c.vasquez
Never mind! I was creating the second sheet incorrectly.
