Inventor Forum
motor windings
13 REPLIES 13
Message 1 of 14
lougalea
3766 Views, 13 Replies
motor windings
I have been attempting to create  motor windings for a small centrifual pump.I found these 2 pictures of windings created with Inventor but i was unable to view them as files.How are the copper wires formed to get the windings like in the pictures attached.
I could only manage the rim in the Inventor file and not the wires
It looks like a wire is created and then patterned but thi looks like a 3D sketch is needed for wire and then circle pattern????
Any help with this would be appreciated
Best Regards
Lou
13 REPLIES 13
Message 2 of 14
lougalea
in reply to: lougalea
It would be nice if someone could help me with this part..even a guide on how to start
Lou
Message 3 of 14
blair
The best would be to do a 3D sketch and sweep the profile of each winding. You will have carefull not to have a self -intersecting sketch. You might be able to create a fair bit on a single plane depending on how the winding travels from the front outside to the front inside. A work-plane might be able to intersect both long-axis of the winding.
Delta Tau Chi ΔΤΧ
Message 4 of 14
lougalea
in reply to: blair
Thanks Blair
Would i make a single winding and use circle pattern tool?
I can do sketches 2D but never done much with a 3D sketch...I know this a is a big ask but could you do possibly a single winding for me to view.I also understand if you are unable due to being busy
Lou
Message 5 of 14
lougalea
Hi
Anyone willing to create 1 of these wires for the windings
Thanks for any help
Lou
Message 6 of 14
SeanFarr
I agree that exploring a part in Inventor does seem to be easier and faster to learn modelling techiques, However when one isn't availble or people are too busy to post one, I look around for some good tutorials.
For Modelling I start here:
they generally get me going in the right direction,
for your need, this tutorial might help:
http://home.pct.edu/~jmather/content/DSG322/Inventor%20Tutorials/Inventor%2011%20Tutorial%207.pdf
 Good Luk!
Edit:
Forgot to mention that I also look for models that have been uploaded to sites such as GrabCAD, people upload all kinds of models and assemblies. I found this one quickly seaching for Coil
http://grabcad.com/library/stupid-coil
Sean Farr
Product Designer at TESInc.ca
Inventor Professional 2014-Update 2 - AutoCAD Electrical 2014
Win7-x64 | ASUS P8Z77-V | i7 3770 -3.4 GHz | 32GB RAM |
240GB SSD | nVidia GTX 670 4GB - 320.49
Message 7 of 14
blair
I am currently away from the office at Autodesk offices in San Fran. If you post your rotor file IPT ill take a look at it when I am back
Delta Tau Chi ΔΤΧ
Message 8 of 14
graemev
Something like this?
Message 9 of 14
lougalea
in reply to: graemev
Yes thank you for the Windings file....i did a search of Grabcab and found the attached picture although it is a Solidsworks file...This Windings looks very good....would this be possible in Inventor
Thanks for the help
Lou
Message 10 of 14
rdyson
Yes, create one "X" shaped sweep. Circular pattern it and then mirror.
PDSU 2016
Message 11 of 14
lougalea
Thanks Mr Rdyson
I do not follow this "create one "X" shaped sweep".Please how do i create the "create one "X" shaped sweep" ?
Thanks again
Lou
Message 12 of 14
rdyson
Well, maybe more of a "V" than an "X".
Attach what you have so far and specify your Inventor version
PDSU 2016
Message 13 of 14
lougalea
Thanks Mr Rdyson
I am using Inventor 2014
Attached is as far as i know to this point
thanks again
Lou
Message 14 of 14
rdyson
PDSU 2016
