Look at using a transitions constraint with a surface...
http://www.mymcad.com/iv_tipstricks_answer2011.html
Sean Dotson, PE
RND Automation & Engineering
www.mcadforums.com
wrote in message news:4899316@discussion.autodesk.com...
is there a way to set the distance that a part may move through? i am still
working on the hoist assembly from one of my other posts, the chambers in
the assembly are constrained about their z axis so that they can collapse
into each other and extend. along with this, i need for the chambers to
stop at certain distances to keep them from pulling apart while in motion.
at the moment, when the top longitudinal rotates along the pivot, the hoist
assembly follows its path, but at a certain point where the assembly should
stop moving, the hoist pulls apart and the longitudinal continues along its
path. i would like to constrain the entire assembly to an angle for the
longitudinal and the coinciding distance on the hoist. thanks, tj
