Inventor General Discussion
Active Contributor
stoob
Message 1 of 7 (5,503 Views)
Accepted Solution
Motion constraints - Turning a screw in a hole?
5503 Views, 6 Replies
04-01-2011 03:28 AM
I am pretty familiar with Assembly constraints but I want to know how do you constrain/motion a screw or similar object to be able to turn appropriately whilst going up & down a threaded hole?
Any help would be great.
Cheers
This is a great reply although I find it quite difficult to set up, would you be able to supply a quick assembly example? :smileyhappy:
Employee
johnsonshiue
Message 2 of 7 (5,471 Views)
Re: Motion constraints - Turning a screw in a hole?
04-01-2011 11:49 AM in reply to: stoob
Hi! There might be other ways to do it. But, the most straight forward one I can think of at this moment is the following.
You have a screw part and a component with a hole. The screw needs to move along the hole axis. I assume you have already create axial Mate constraint for the two. To make the screw rotate during a translation movement, you need another trigger to do that. I do not think the screw can rotate by itself based on how Inventor asembly constraints work. The solution is to create a piggy-back part. It can be a simple box part. and it is constrained to the screw in a way that when screw moves the pb part will follow. Next add a Motion:Rotation-Translation constraint between the screw and the pb part. After that, when you drag the pb part, the screw will move and rotate.
Would it work for you?
Thanks!
Senior Principal SQA Engineer, Inventor
Mechanical Design
Autodesk, Inc.
Active Contributor
stoob
Message 3 of 7 (5,455 Views)
04-01-2011 02:08 PM in reply to: johnsonshiue
Employee
henderh
Message 4 of 7 (5,443 Views)
04-01-2011 02:45 PM in reply to: stoob
Here you go!  (assembly attached in zip file)
  You can change the pitch using the translation / rotation constraint distance parameter
Thanks, -Hugh
Hugh Henderson
Simulation QA Engineer
DLS
Active Contributor
stoob
Message 5 of 7 (5,426 Views)
04-02-2011 12:09 AM in reply to: henderh
Awesome and really neat! Thanks for that great example and working on it. I love these forums! :smileytongue:
I had a go myself and I understand the principles to this.
It would be good if Inventor had this function written into the program where you just have to move the part you want moved and rotated, on my wish list!
S
Valued Contributor
WillieArolf
Message 6 of 7 (5,045 Views)
02-06-2012 04:56 PM in reply to: johnsonshiue
Its kind of weird though that, you need to have another object in order for the screw to rotate. I also do not have idea as to how to make the screw rotate. There are few youtube videos showing a screw rotation. How did they to that?
If I need to animate a screw rotation. Any tips woukd be appreciated.
Thanks & Regards,
Willie
Autodesk Product Design Suite Premium 2012
Windows 7, 64-bit
*Expert Elite*
JDMather
Message 7 of 7 (5,027 Views)
02-07-2012 04:05 AM in reply to: WillieArolf
The dummy part is not needed.
Autodesk Inventor 2015 Certified Professional
Inventor Professional 2015-SP1 64-bit
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
