Inventor General Discussion
*Bogan, Bill
Post 1 of 8
Motherboard question
37 Views, 7 Replies
11-12-2002 08:40 AM
For Single CPU use.... whose Mboard is among the better performers?
For those of you running dual CPUs -
When it comes to running dual CPUs, what motherboard choices
have you found and any comments about your experience or quality of the
board?
Many thanks,
Bill Bogan
*Corbin, Brian
Post 2 of 8
Re: Motherboard question
11-12-2002 09:33 AM in reply to: *Bogan, Bill
Bill,
Asus have a new board based on the new NVIDIA Nforce2 chipset which has dual
channel memory (when using 2 DDR's) Which should be a great performer. Also
running a new Athlon 2400 or 2600 XP will give awesome bang for buck.
If money is no object then Intel is just about to unleash its new 3gig
processor with hyper threading which will be interesting to see how that
helps speed up Invenotr with large drawings. Basically the hyperthreading
CPU is seen as 2 CPU's under win2k and XP. Not the same as 2 true CPU's but
could be a boost all the same. Coupled with 1066mhz RDRAM this sytem would
truley fly.... but at a cost..
http://www.intel.com/technology/hyperthread/
Brian
"Bill Bogan" wrote in message
news:5320863778859DA56B59CDED8238C276@in.WebX.maYIadrTaRb...
> board?
> Many thanks,
> Bill Bogan
*Keller, Kent
Post 3 of 8
11-12-2002 09:49 AM in reply to: *Bogan, Bill
I have a 1+ year old Tyan mb, and I can't say I really push it, but I have
no complaints with it.
Kent Keller
Member of the Autodesk Discussion Forum Moderator Program
http://www.MyMcad.com/KWiK/Mcad.htm
> board?
> Many thanks,
> Bill Bogan
*Crain, Ron
Post 4 of 8
Re:
11-12-2002 10:07 AM in reply to: *Bogan, Bill
Ditto. I have the same MoBo as Kent and it's the most trouble free
motherboard I've ever used.
*Bogan, Bill
Post 5 of 8
Re:
11-12-2002 02:25 PM in reply to: *Bogan, Bill
Thanks guys. That helps narrow the field on the duals. Plus a little
discussion about the future.
Oh, and Brian, for the record, money WILL be an object.
Bill Bogan
"Ron Crain" wrote in message
news:0A92848000948D1AF37F2378887349F4@in.WebX.maYIadrTaRb...
*Burton, David
Post 6 of 8
11-12-2002 08:57 PM in reply to: *Bogan, Bill
There are a ton of motherboard sites out there - a good review site to check
out is www.anandtech.com it isn't CAD centric but it has some good
information about stability and drivers
Dave Burton
SICO Inc
http://www.sicoinc.com
> board?
> Many thanks,
> Bill Bogan
*DJSpaceMouse
Post 7 of 8
11-12-2002 09:10 PM in reply to: *Bogan, Bill
I have always bought Soyo mobos. They're great to work with - no jumpers -
and fairly inexpensive. I posted before that I prefer to stick with Intel
chipsets, by I think that's just personal preference. I know people that
swear by VIA chipsets.
> board?
> Many thanks,
> Bill Bogan
*Corbin, Brian
Post 8 of 8
Re:
11-13-2002 04:34 AM in reply to: *Bogan, Bill
Bill thenI would lean towards an Athlon XP. I just built a 2200+ on an BAIT
KT400 motherbard. As long as you get a nice case (at least 3 fans, Good
power supply (~400watt) and quality RAM (I used Corsair XMS 2x512) then it
should be fine. My new system has been rock solid since day 1 (INV 5.3).
I do wish I had know the N-Force2 MB's were just around the corner though...
Brian
news:56B56DA918927C6F4A58B7C31BC23318@in.WebX.maYIadrTaRb...
> Bill Bogan
