Inventor Forum
More nuber as alias problem
4 REPLIES 4
139 Views, 4 Replies
Just had two crash to CER's that may have been related to contact set
After restarting the second time, I discovered that all of the alias that
started with a number were gone
All the other customized aliases / shortcuts were unaffected
4 REPLIES 4
I suspect that like most other setting in IV they are not committed until
you do a clean shutdown. So try this, open IV, make your changes and then
close IV. The next time you crash check to see if they are remembered.
Sean Dotson, PE
RND Automation & Engineering
www.RNDautomation.com
www.mcadforums.com
"Ray Dyson" wrote in message
news:5568548@discussion.autodesk.com...
This was after more than one clean shutdown though and they had stuck.
"Sean Dotson" wrote in message
news:5568862@discussion.autodesk.com...
Sean Dotson, PE
www.mcadforums.com
Well it was worth a shot. Sorry.
Sean Dotson, PE
www.mcadforums.com
news:5568905@discussion.autodesk.com...
Sean Dotson, PE
www.mcadforums.com
Thanks for the try
news:5568938@discussion.autodesk.com...
Sean Dotson, PE
www.mcadforums.com
Sean Dotson, PE
www.mcadforums.com
