Inventor Forum
MOLD Design - cutting surface
19 REPLIES 19
Message 1 of 20
Henrik_Lo
1496 Views, 19 Replies
HI
I have a question regarding a model having a little odd design. The planed cutting surface is not
the best solution becourse there are negative edged involved. The planed surface it that one switched on for the moment.
My question are, is there a way inventor can advise a curved surface for cutting, and in optimal way or, optimal points
I know it is an difficult question, and maybe difficult to explain too.
Regards
Henrik
19 REPLIES 19
Message 2 of 20
Henrik_Lo
in reply to: Henrik_Lo
HI
My system:
Autodesk Product Design Suite Ultimate 2013
Windows7 pro 64-bit
Intel(R) Core(TM) I7-2720QM CPU @ 2.2GHZ
Memory 8GB
Regards
Henrik
Message 3 of 20
sam_m
I don't have 2013 so cannot open the file, but are you trying to find the optimal split-line along a curved shape?
can you use the 3d sketch "silhouette curve" command to do this?  (will give you a sketch around the part where the draw-angle is zero - ie the split-line).
help for it:
http://wikihelp.autodesk.com/enu?adskContextId=TOOLTIP_SKETCH3DSILHOUETTECMD&language=ENU&release=20...
Sam M.
Inventor and Showcase monkey
Please mark this response as "Accept as Solution" if it answers your question...
If you have found any post to be helpful, even if it's not a direct solution, then please provide that author kudos - spread that love 😄
Message 4 of 20
Henrik_Lo
in reply to: sam_m
HI, ill will try to look into this feature, I had the file saved in STEP format
regards
Henrik
Message 5 of 20
Henrik_Lo
Hi
Iam able to make this silhouette curve, but I need to make a surface to cut the item, if you study the curve, there are some small lines seem to go opposite direction, is I possible to smoothen this out for making this perfect surface.
Regards Henrik
Message 6 of 20
MingweiGao
hi Henrik,
Did you use the Mold design in Inventor professional?
I suppose you will adjust the mold open direction of this part for the specific structure. Like below attached picture.
I also try to do the mold in Inventor Mold design, the results as attached.
BTW, the runoff creation command in Mold Design can search the silhouette curve and you don't to create them manually.
Steven Gao
Sr. SQA Engineer
Message 7 of 20
Henrik_Lo
in reply to: MingweiGao
HI, thanks for replaying, this is exactly what iam after.  I only look into this MOLD design module briefly, but I can see
The force for this MOLD design module in inventor.
But I think I need some more training before I can use this software
Regards
Henrik
Message 8 of 20
JDMather
Regards
Henrik
In addition to the built in Tutorials for Inventor Tooling (Mold Design) you might try this tutorial
http://home.pct.edu/~jmather/content/DSG322/Inventor%20Tutorials/Inventor%202011%20Tutorial%2014.pdf
The CADWhisperer YouTube Channel
Message 9 of 20
JDMather
@MingweiGao wrote:
hi Henrik,
Can you explain how you selected the parting line for the Runnoff Surfaces without creating silhouette curve?
I selected manually, but had to have a screen capture image of the Opening Direction to use as a guide and got slightly different results.  I didn't see an automatic or easy visual way to select the parting curves.
Message 10 of 20
JDMather
in reply to: JDMather
If I set Draft view in the derived part I get a persistant guide view, but the silhouette edges are still rough.  Did you use some other technique other than manual selection to create the runoff surfaces?
(Automatic creation didn't work for me.)
Message 11 of 20
Henrik_Lo
HI
It is my first time to use silhouette curve, i must admit is an amassing tool, together with the MOLD software
I just used the silhouette curve command, and automatic selection a gess
I will tray to go truth you steps and tray to get the same model as you did.
Regards
Henrik Lørup
Message 12 of 20
MingweiGao
hello, JDMather,
Please refer to the following links about using silhouette curve to create hole patch and runoff.
http://wikihelp.autodesk.com/Inventor/enu/2012/Help/0000-What's_N0/0051-Tooling51/0060-Surface_60
http://wikihelp.autodesk.com/Inventor/enu/2012/Help/0000-What's_N0/0051-Tooling51/0061-Runoff_S61
BTW, for hlo's specific part, I wasn't used the whole silhouette curves of this part to create runoffs because of two small twisty regions and I connected the  adjacent runoffs directly.
Steven Gao
Sr. SQA Engineer
Message 13 of 20
Henrik_Lo
HI
Tangs for helping, i will study all regarding this MOLD design
Regards
Henrik
Message 14 of 20
Henrik_Lo
Hi
I need to re-open this tread.
I did some study in Mold software and Core/Cavity, but this item I do have some problems with.
I need to know if there is a way, to make the runoff easy by using the silhouette curve. I know form reply, from the command I using to generate core and Cavity, some problems are exciting.
The item “Item1.ipt” I used the “silhouette curve” and tried to make runoff surface but it is not working.
The item “Mold Design Emne 1_Mold Item-silhouette curve_MP.ipt” I did some modifications and got finely a runoff surface, but still error.
Is this item just to messy designed og what, to making the runoff surface the will do the job.
Regards
Henrik
Message 15 of 20
MingweiGao
Can you pack and go your all Mold design files and send them to me(Mingwei.Gao@autodesk.com)? From your provided two parts, I cannot see any runoffs in them and missed some reference models.
Steven Gao
Sr. SQA Engineer
Message 16 of 20
Henrik_Lo
HI
I did the pack and go, hope something will come out for it.
Regards
Henrik
Message 17 of 20
MingweiGao
Hello Herik,
I had a look at your Mold design datasets and I have to say the silhouette curves of this part are very complicated and some regions are not suit for parting lines. The current result looks not realistic for Mold manufacture. This is also the reason of core and cavity split failure. Can you modify the silhouette curve in some regions to let the parting lines smooth and then create the related runoffs?
Steven Gao
Sr. SQA Engineer
Message 18 of 20
Henrik_Lo
HI
Thangs for having this second look at this part, I just need to be sure that I didn’t foresee
something. I will tried to do modification much mort to be able getting the right result
Regards
Henrik
Message 19 of 20
MingweiGao
Henrik,
If you are interesting in my testing design result of your model, please give me a Mail address and I can send it to you. Because the file size of the all design files is about 5M and I cannot post it in here.
Steven Gao
Sr. SQA Engineer
Message 20 of 20
Henrik_Lo
Hi, I like the testing design from you, my mail are
hlo@rmig.com
Regards
Henrik
