Inventor General Discussion
lucmartzz
Message 1 of 11 (807 Views)
Mold design and content center
807 Views, 10 Replies
04-30-2012 12:05 AM
Hi, here I need some help
I did my Autodesk Inventor Professional 2013 installation few days ago, yesterday I started working with mold design and when I try to set a material appears an error "The Moldflow analysis server is terminated". So I found on internet that it's an installation problem.
I did a clean uninstall products and reinstall (Just leave Vault products).
Now the error persist and my content doesn't appear. I work with Vault content center, but I tried installing desktop content but the same result.
Thanks.
Product Support
dave.anderson
Message 2 of 11 (783 Views)
Re: Mold design and content center
05-04-2012 11:03 AM in reply to: lucmartzz
I head of this in 2012 and SP1 resolved the issue.
If you are using 2013, try using the Right-Click> Run As Administrator on the desktop shortcut. it's possible users permissions are blocking the ability. Another possibility is anti-virus & Anit-malware. Try disabling them and then use Run As Admin.
Dave Anderson
Premium Support Analyst – DLS Mechanical Design
If I have answered your question, please "Accept Solution" so others may benefit as well.
Active Member
seplggn
Message 3 of 11 (760 Views)
05-10-2012 04:28 AM in reply to: lucmartzz
I have faced similar problem with Inventor 2013, clean install and 30 days validity the problem persists. I even tried to bypass windows fireball, no luck.
The software gets stuck at material selection. Hoever you can still work on core cavity but one cannot set process parameters since material selection has not taken place.
lucmartzz
Message 4 of 11 (741 Views)
05-14-2012 06:13 PM in reply to: lucmartzz
I got back to 2012 for continue my work and I had no problems.
Today I did a clean installation of 2013 but the problem persist...
lucmartzz
Message 5 of 11 (704 Views)
06-11-2012 05:22 PM in reply to: seplggn
At the end of all, I have just reformatted my computer and everything works perfect.
Active Member
seplggn
Message 6 of 11 (674 Views)
06-27-2012 08:21 PM in reply to: lucmartzz
What is your windows version?
lucmartzz
Message 7 of 11 (661 Views)
06-28-2012 06:34 AM in reply to: seplggn
Windows 7 64 bits
New Member
knrdptr
Message 8 of 11 (541 Views)
11-09-2012 02:55 PM in reply to: lucmartzz
I'm using Inventor 2013, and I'm having the same problem. Just installed the newest SP, but still the same. Any ideas how to fix this? (besides installing another version) Using Win7 32bit, student version.server error.jpg
Employee
MingweiGao
Message 9 of 11 (504 Views)
11-11-2012 06:00 PM in reply to: lucmartzz
As Dave suggested, do you try to disable anti-virus & Anit-malware and then use Run As Administrator? This is a Moldfolw server issue and all commands related to Moldflow will be disabled if it is not resolved.
Mingwei Gao
Software QA Engineer
Inventor Quality Assurance Team
lucmartzz
Message 10 of 11 (487 Views)
11-12-2012 06:36 AM in reply to: knrdptr
Probably your computer had more than one preview version instalation of Autodesk Inventor. Anyways if you had uninstall this versions looks like always affect. I did a recover of my sistem to the original state from the manufacturer and works without problems. My computer had installed versions from 2009.
