I recently started doing test with materials and I think I'm starting to understand how it works now. The place I work for want to rename some of our materials in inventor but before I decided to test how the content center parts would react to such modifications. I modified the material name but the already inserted parts from the content center don't seem to update. If I import another size of bolt, the new material name appears fine. In the assembly, I tried using the refresh content center command but it tells me there are no parts to refresh. I also tried to open the part but I cannot edit it. Is there a way to modify the material name and update the already inserted parts?
