I think if all you're looking for is a static part then you can copy the
iPart factory that you get jam nuts from into your project folder. Then open
the file and turn the ipart factory into the part you want. Then delete the
table that makes the part an iPart Factory and that will turn it into a
"static" part. Then you can go in and edit the description of the thread.
Save, close, and insert.
Jack
"Jay Greenfield" wrote in message
news:25A0E4479C30E927E464002DEAC9FEE2@in.WebX.maYIadrTaRb...
> Isn't there a way to just drop the Library part from the file and move
along
> as though I had just drawn it?
> "Sean Dotson" wrote in message
> news:204969982CDC0A09AE1BFD139AF95739@in.WebX.maYIadrTaRb...
> > Wait a second I just reread your question. You mean a content library
> part?
> > You don't. Insert a new one from the content library with the correct
> hand
> > threads. If it doesn't have left hand threads then I'd seriously start
> > looking at iParts...
> > You'll still want to read my first post and keep it in the old memory
> banks
> > Sean Dotson, PE
> > http://www.sdotson.com
> > Check the Inventor FAQ for most common questions
> > news:CFB902B599F62ADC501D96089C31B02C@in.WebX.maYIadrTaRb...
> > > Two ways:
> > > 1) Move it out of the library path edit it then put it back or,
> > > 2) Make a project that points to the library paths as workspace or
> > > workgroup paths
> > > Sean Dotson, PE
> > > news:EB5D8614A7D9EBFECBBF82691FD661E8@in.WebX.maYIadrTaRb...
> > > > I have a jam nut and need a copy of the same nut with a left hand
> > thread.
> > > > Both nuts are in the Project Folder but I can't edit the threads to
> make
> > > > them left handed. How do you convert a library part to an
individual,
> > > > editable part?
