Inventor Forum
modifying diameter and radius dimensions
4 REPLIES 4
jbellric
1099 Views, 4 Replies
My company is trying to Standardize all drawings produced to 1 format.  the one we are attempting to create would be in the form of: nominal upper limit^lower limit.  this is easily acheived in autocad and linear, chamfer, and hole/thread dimensions in inventor.  but radii's and diameters from a round surface (as apposed to linear diameters) we have run into a snag with.  We cannot seem to find a way to either remove the prefix symbols or be able to insert text between the symbol and tolerance.
below is a illistration of the problem and the form of the new dimensions.
if anyone knows where i can find these controles, the information would be much appreciated.
4 REPLIES 4
JDMather
in reply to: jbellric
@jbellric wrote:
My company is trying to Standardize ....
What standard are you using?  (Example - ASME/ANSI Y14.41).
jbellric
in reply to: JDMather
we aren't really using a set ANSI standard right now.  every engineer has his own method right now.
JDMather
Perhaps the easiest way to introduce and enforce a common standard is to agree to use a National Standard.
jbellric
I have been trying for the last 3 years but this is what the management feel is our better option.  so back to the original question: Is there a way to remove the diameter and radius symbol from appearing on their own?
