Inventor General Discussion
jbellric
Message 1 of 5 (660 Views)
modifying diameter and radius dimensions
660 Views, 4 Replies
10-23-2012 09:56 AM
My company is trying to Standardize all drawings produced to 1 format.  the one we are attempting to create would be in the form of: nominal upper limit^lower limit.  this is easily acheived in autocad and linear, chamfer, and hole/thread dimensions in inventor.  but radii's and diameters from a round surface (as apposed to linear diameters) we have run into a snag with.  We cannot seem to find a way to either remove the prefix symbols or be able to insert text between the symbol and tolerance.
below is a illistration of the problem and the form of the new dimensions.
if anyone knows where i can find these controles, the information would be much appreciated.
JDMather
Message 2 of 5 (615 Views)
Re: modifying diameter and radius dimensions
10-23-2012 12:26 PM in reply to: jbellric
jbellric wrote:
My company is trying to Standardize ....
What standard are you using?  (Example - ASME/ANSI Y14.41).
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
jbellric
Message 3 of 5 (612 Views)
10-23-2012 12:30 PM in reply to: JDMather
we aren't really using a set ANSI standard right now.  every engineer has his own method right now.
JDMather
Message 4 of 5 (582 Views)
10-23-2012 01:52 PM in reply to: jbellric
Perhaps the easiest way to introduce and enforce a common standard is to agree to use a National Standard.
jbellric
Message 5 of 5 (574 Views)
10-23-2012 02:19 PM in reply to: JDMather
I have been trying for the last 3 years but this is what the management feel is our better option.  so back to the original question: Is there a way to remove the diameter and radius symbol from appearing on their own?
