Inventor General Discussion
Pebblebrook
Message 1 of 5 (481 Views)
Modifying 3D dimensions in Inventor LT
481 Views, 4 Replies
05-23-2012 08:55 AM
Quick question...
Once a 3D object is drawn/completed in Inventor LT, how does one go back to the object to change the length/radius of certain objects without having to completely redrawn the object.  For instance, imagine a bike wheel that is fully draw.  Later perhaps one wants to go back to the wheel and adjust the radius of the spokes and the length.  How does one do this quickly.  In 2D I see how, but can this also be done in 3D with Inventor LT?
Any help is greatly appreciated.
pb
_______________________________________________________________
Working with... Autodesk: AutoCAD Inventor LT Suite 2013 | OS: Windows 7 | GC: ATI 6670 | Mem: 8 gigs RAM | Proc: Intel core i5 | Monitor: Acer V213HL
mcgyvr
Message 2 of 5 (479 Views)
Re: Modifying 3D dimensions in Inventor LT
05-23-2012 08:59 AM in reply to: Pebblebrook
I'm not familiar with the limitations of LT.. (I thought you just couldn't make assemblies/iam files) so I'm assuming the part environment is identical to regular Inventor.. And if so you simply open the ipt file and edit the 2d sketches used to create the 3d features.
You should have the model browser tool bar open and look at the tree and find the feature you want to modify then simply right click and select "edit sketch"
Down with IDW/DWG files..... Long live 3D PMI... Hurry it up already..
2015 Product Design Suite Ultimate
Windows 7 64 bit
Core i7 4820k processor (OC'd to 4.4Ghz), Nvidia GTX 770, 16G RAM
Curtis_Waguespack
Message 3 of 5 (473 Views)
05-23-2012 09:10 AM in reply to: Pebblebrook
Hi Pebblebrook,
As mcgyvr mentioned you'll find the edit tools in the right-click of the feature browser node of the model. Choose Edit Sketch to edit the 2D, and Edit Feature to edit the 3D. When editing a feature you are presented with the same tools used to create the feature originally.
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
Pebblebrook
Message 4 of 5 (468 Views)
05-23-2012 09:24 AM in reply to: Curtis_Waguespack
Thank you for your posts.  We found an option called 3D grips that changed the 3d image into a wire frame and allows us to adjust it there. but if this option fails, ill be sure to use the one's you provided.
Thanks again
pb
mcgyvr
Message 5 of 5 (462 Views)
05-23-2012 10:27 AM in reply to: Pebblebrook
Thanks again
pb
You skipped the basics with that method which I would NEVER suggest as you are clearly a beginner. Learn to edit the features sketches by the methods we talked about.. Then later use 3d grips if you want.
Windows 7 64 bit
