Inventor Forum
Modify part causes flat pattern orientation to change
2 REPLIES 2
drguitarum2005
612 Views, 2 Replies
A coworker of mine called me up to tell me about a problem he ran into. He had a sheet metal piece with a flat pattern and dimensioned the flat pattern on his Inventor DWG just like he wants it. He noticed he needed to fillet 2 corners in his model. He applied the fillet, saved it, and when he came back, his flat pattern was rotated 180*. Going into the flat pattern itself, the "Front" on the view cube was upside down from what it was and the view cube could not be re-oriented.
Why would adding two simple fillets redefine the orientation of the flat pattern?
2 REPLIES 2
rdyson
in reply to: drguitarum2005
Without the file, it's impossible to guess what happened but this can be used to re-orient the flat pattern and will 'restore' the dimensioned drawing to it former state.
PDSU 2016
3ddrafter
in reply to: rdyson
Finally someone that can answer this! Thank you so much. I have looked this up a couple of time and could not find an answer.
