The material property can only be controlled by VB(A) or by means of iParts.
Currently you cannot control the material by an Excel spreadsheet (unless
it's an iPart).
Sean Dotson, PE
Autodesk Inventor Certified Expert
http://www.sdotson.com
Check the Inventor FAQ for most common questions
www.sdotson.com/faq.html
"bkline" wrote in message
news:3605677.1075750369111.JavaMail.jive@jiveforum2.autodesk.com...
> I currently have an assembly model set up to be parameter driven by an
attached excel spread sheet. With this parameter sheet I am able to drive
the size and shape of all 7 parts of my assembly. I would like additional
functionality to be able to control what material all 7 pieces are
constructed from by simply modifying the top level spread sheet. Is this a
possibility? I am new to Inventor, but I have been able to catch on quickly.
I am aware of the capabilities of writing a macro using VB, but
unfortunately at this time, I have not had any time to try and learn code
writing. Any help would be greatly appreciated...
